True, when you add up the functional features such as Direct Tilt Control + Free to caster + Quad/Delta Switch-Over, my build looks complicated. But, I have constantly striven to keep the design and build of each feature as simple as I could. And, now I'm becoming convinced that the current ride-feel in different riding situations (slopes, bumps etc.) in one way or another validates the embodiment of Caster Steering and Direct Tilt Control.
RIDE-FEEL Side Slopes & Speed Bumps
Locating a suitable slope and bump where I could video the ride action proved to be difficult. So instead, I simulated the ride situations on my driveway.
The side slope scene in the fist video takes place at curb side. Upright parking is maintained on this slope by setting the park-brake, which locks the rear wheels creating a lean-lock effect. The slope from the bottom of the curb to where the right wheels track across the driveway is 14 degrees.
After I release the park-brake, I simply hold the Tilt Control apparatus in a position which keeps the cabin upright (variable lean-lock) and pedal forward. I use thumb steering to traverse the slope and turn down onto the roadway.
Side slope riding is easily accomplished within a range of slopes, speeds, and curves. On gentle slopes such as the crown on roadways, thumb steering is not required. I just hold the tilt mechanisms to keep the velo in an upright posture (more inline with gravity than road camber) and rely on F to C Steering to maintain my straight-ahead direction.
The next side slope video shows the quad heading towards the driveway at an angle to the curb.
A few years back, when I first attempted pedaling up the driveway in my proof-of-concept model, I experienced some alarming moments. Originally, I tried synchronizing the movements of the tilt levers to avoid a quick tilt to the left as the right rear wheel rode up over the curb and the left rear wheel was still at road level. But, whenever my timing was off, the ride felt destabilizing. So I developed a riding technique which continues to be comfortable and consistent.
This technique results in keeping the cabin and frame in a substantially upright posture while riding over the curb at an angle as well as over other bumps or depressions.
The technique is simple and easy to do. I just hold the thumb levers steady and allow the tilt levers to move freely. This strategy lets the rear swingarms move freely up and down without interfering with the upright posture of the cabin and frame. And, I don't have to think about getting the timing right or the nature of the bumps/depressions.
My slogan for this technique became "Steady the Steering-Hang Loose-Enjoy the Ride". It works. The ride feel is similar to my single track bicycle in that an upright posture is maintained when I ride over the curb and up the driveway at various angles.
This technique is also applied in the next two videos simulating travel over a speed bump (a pallet with each end-slat re-positioned to serve as on/off ramps).
In the first instance I just hold both thumb levers steady and the tilt levers loosely.
In the second instance, I avoid a destabilizing tilt to my left by holding the thumb levers steady and allowing the tilt apparatus to move freely (hang loose). The ride feels quite stable because limited lateral forces are felt.
In contrast, a narrow track, non-tilting velo-quad, ridden over a wooden pallet in this manner would likely feel awkward and the lateral forces most certainly felt as first the front wheel and then the rear right wheel travel up and over the pallet.
In the video I purposely run the right wheels close to the edge of the pallet to ensure I have sufficient clearance for the bottom of the tilt lever. On my first attempt at this maneuver, the spur of the high-sided tilt lever scraped and dug into the wood on top of the pallet. Thankfully this is not an issue for everyday riding.
COMPARING the RIDE-FEEL (Cabin on-vs-off)
Without the cabin, the ride is quieter, especially over bumps & depressions. So I will be sticking weather-stripping on the frame of the cabin (where it makes contact with the tail section) to minimize the clanging sound of metal on metal.
Without the cabin, the ride generally feels more free and nimble. But my clear view of the front wheels (with the cabin on) is reassuring and it allows me to perform the same riding maneuvers-even in tight situations.
So while it's a different ride-feel, It's one I'm willing to accept to obtain the advantages of an enclosed vehicle.
During my test rides, I discovered a surprise benefit of riding with the cabin on. It will be the focus of my next post.
