Hi folks (← me being gender neutral, inclusive and totally PC here)
... back to the plot..
I have 2 previously made steerer's (threaded headset fork heads with tabs on for attaching axles) (like for a Street fox etc.).
Problem: They are not both at the same angle, there is a 2° difference between the angles their axle mounting tabs are at in relation to the axis of the steerer tube.
Q. What's the best way of getting them at the same angle?
Thanks in advance.
- Do I hack one tab off and try to get the angle the same as its twin when replacing it?
- Cut a slit in the outside of one tab at the root and open the gap and then fill with weld?
- Run a thick bead on BOTH but on opposite sides of their tabs to get the contraction on cooling to take 1° out of each but in opposite directions?
Thanks in advance.
