So better attempt at traditional handlebars and other hardware added......
So we have brake hardware installed however we don't have a brake only a retarder , needs some fiddling as it cannot currently stop the device.
The less cluttered side , looks clean from here.
As there is a huge amount going on here , I did manage to derail the chain today [ first time ] sat on it with maximum right lock and walked it backwards after some clattering it fell off the crank ring. A reminder it needs guards and I need my front wheel disk on to stop the mess ending up in the spokes. Yes you can go over the handle bars should you lock the front/rear wheel at speed.
This is the view from the cockpit at about eye line so plenty of vision however the bars can be lower still when I have attended to other matters.
I have expanded the rides now with my new found slowing power and I/it has now done 3 rides of 561m so 1.3 km or about 1 mile.
Many many things need attending to , in no particular order:-
1) I noticed small flecks of black plastic on my legs - the chain is chewing it's way through the black pulley at a tremendous rate !
2) Seat needs to be further forward - in my ' non cycling shoes I am hitting the derailleur with my heal:-
So I hope to get cranks further forward and this should go away.
3) very hard to get any gears - Hanger needs bending outwards a little [ why I can't get the lowest gear ] H & L stops need adjusting.
4) I noticed a slight swaying maybe only 1/2" when attempting to turn I found numerous bolts loose on the rear axle AND the seat not helping.
5) It seems to feel as though it wants to tip over - well it hasn't and probably can't easily however with a 8" seat height and 24" rear track I expected to have more confidence/faith in it than I currently have - seat time and a couple of of sh*t moments should sort that out.
Should I be worried about the brake arms ? they seem to be pointing into the centre of my calf muscle , I think it could really spoil your day if they did make contact !!!
Moving the seat forward moves the crown jewels ever closer to the vertical frame member , should I really worry about this ? I mean if I should have an ' episode ' will 2.5" of space there really save me ? The seat is in front of them just.
It is much better at dealing with camber changes especially now it does not ' sway ' from side to side as you traverse the camber.
DannyC and I have been discussing the possibility of rear wheel drive using something like this :-
It is an Italian designed rigid axle for a pedal car.
So no diff just a cassette & free wheel tied to a M15 axle going through 2 x pillar block bearings , they say no problems if track width is kept narrow , as I am shooting for less than 18" it should be fine.
Pro's :-
front fork much simpler
much easier to get good gearing
Con's:-
all that chain
chain has to pass under seat
possible more weight
As an aside I bravely remove my hands from the handlebars and continued to pedal - it went as straight as a arrow - that's a relief should be less tiring to ride if I am not fighting to keep it on a course.
