So mulling over the rear axle problem , that in all honesty could be easily made by the Southern lathe boy [ you know who you are
I found a non lathe solution amongst my parts...
So in upper left is some electrical conduit which has printed on it 25mm
Inserted is a M12 coupler outside is 19mm - a snug fit
Washer wheel [ shown by wood ] washer and lock nut - all assembled on a length of M12 threaded rod running the full width of the axle.
Loosely assembled we look like this , this is 24" between tyre centre's now this is the training axle used whilst we get the FWD tamed and
some seat time ultimately I want an axle only just smaller than my across the shoulder width.
Now it would be nice if I did not have to keep building a new one as I move down say 20" then 18" any maybe 16" !
I realised if I only welded one of the M12 couplers in the tube the other could simple be locked by a normal M12 nut snugged up to the coupler before the washer - wheel - washer - lock nut.
Shortening the axle then just involves shortening the outer tube , re-assembling the loose coupler and shortening the M12 all thread.
Simples
As shown the assembly weighs 3.2kg and the front end weighs 9.18kg = 12.38kg however we are short of cranks,chain and brakes at this point
I think there is some room for lightness ?
That tubing must have a thickness of 25mm - 19mm = 6mm so 3mm wall , I am sure 1.5mm wall would be strong enough.
Interestingly the wheels as show alloy hubs [ narrow ] Schwalbe road tyres are 1 kg , not sure there are any racing tyres in 305mm which could be lighter ?
So tube + bits must weight 3.2kg - [2 x 1 kg] so 1.2kg
Of course if I chopped it down from 24" to 16" that could reduce the weight by maybe 0.6kg so heading in the right direction.
Still a long way to go , however it seems more likely to work than the pedal car !!!
