Hellow fellow zombies!
I'm in the middle of making a warrior trike, and it's a whole load of fun! My first every metal working project too! look! Isn't she a beauty?
I've been looking around on this forum as well for inspiration and possible pitfalls, all super interesting.
One thing I noticed is that some people on the forum are adding extra bits and bobs to strengthen up the frame, mainly the rear fork and the side arms. That sounds pretty smart, but it is adding more and more weight to a steel frame that is already pretty heavy...
I was wondering if anyone has done any weight-load testing on the frame to determine how good/bad the welds are? (me being a rookie welder, that might go both ways...) and wether I should reinforce the frame... I figured: my weight (80-ish kg) devided over 3 contact points, would mean the rear fork should be able to take MINIMUM 28kg, same as each individual side arm. Adding a safety factor of maybe 2 (?) should give me some viable numbers to work with ... I think? Anybody have any experience with this? Is safety factor of 2 reasonable, for when I go over a bump at speed? How do you know what safety factor you should pick?
Thanks for the help!
Simon
Simon
