If you are building something near 50kg you will need to be in s very flat area and/or will need electrical assistance. Trying to pedal such weight uphill will be a killer even for a young person in top fitness. You will need a lot of gears with very low gearing to even begin to shift it. I would advise anyone to aim for a 25kg limit without a motor.
Pedalling any recumbent uphill is harder than a regular bike and the last time I looked Switzerland wasn't flat.
On a tadpole your weight is 2/3 over the front wheels. When you brake your weight can go entirely over the front so the rear has zero grip. In a corner that means even mild braking will lock it up meaning the rear overtakes the front and you crash. The same will apply to any quad using the same seating position. If you want rear brakes you will need to get your weight further back than a standard tadpole design allows meaning a longer wheelbase meaning more chassis as you then place more weight over the chassis rarther than the wheels. It also means your feet then want the same space as the front axle meaning the front wheels then have to go much further forward still so the pedalling space is behind the front axle meaning even more chassis. Negatives all round just to get unnecessary extra brakes which themselves add weight.
It is the easiest thing to add weight you can not move.
3 wheels will always make contact on even the most rough ground. 4 wheels will not. There will be times when a 4 wheeled vehilcle will lift a wheel. Suspension will help with that.
I rarely see any recumbent using full front forks that looks good. They almost universally look like they are a compromised design because the designer would not use single side mounted wheels.
