ADDING e-ASSIST Thanks to an AZ post
About two years ago I mentioned to Hugh that I was looking forward to eventually getting my project to the stage of his completed e-delta. At that time I was planning on using a 500 watt single-sided All Axle Hub motor. That hub motor, which is designed to be placed onto the front wheel(s) of a tadpole, could also be mounted onto the left rear swingarm of my velo.
Well, this past winter, as I thought about installing that hub motor, I began to consider the structural modifications I would need to perform on the velo to accommodate it. For starters, the hub motor comes with a spoke wheel which would require slightly different dimensions for the swingarm. I would also have to modify the tail section to accommodate the placement of the caliper brake between the spoke wheel and the shell.
To top it off, after these modifications, I would still end-up with miss-matched wheels (a spoke e-hub on the left, with its externally mounted brake, and a yellow Fiber Glass wheel on the right, with its brake tucked inside the shallow dished wheel behind the blue aero-cover). Not good.
So, I began to look for optional ways to install e-assist. That's when I came across AZ members discussing the pros and cons of a 450 watt brush motor with controller etc. This item is sold as a kit designed to be mounted onto the left side of a bicycle to drive a sprocket fastened to the spokes of the rear wheel.
Well, I immediately saw the possibility of this kit to be easily mounted onto my velo's rear swingarm without modifications.
So I ordered the kit.
The photo below shows the 450 watt motor mounted onto the left rear swingarm with a chain to drive the original FG wheel.
So, thank you to the AZ members for posting that information. (I think it was stormbird and Popshot).
I now have an inexpensive and simple to install e-assist set-up.
The next photos show that, except for the single-sided front swingarm with wheel attached, the rest of the velo remains unchanged.
The camera angle in the next photo depicts the zero degree rake of the steering axis a little better.
My next step is to fabricate a fiber glass nosecone for the delta.
Cheers.
Wally
