My seat is a bought one , just a plastic molded job like a refuse bin.
Whilst the AZ seats are easy to make they can lack lateral support needed on trikes [ as most don't lean around corners ] and they can be very sweaty as the temperature rises.
My seat has a Ventisit seat pad, sort of 3D plastic mesh that allows air to circulate underneath me , the material is made to go under mattresses in campers and boats to stop damp causing mildew etc
Ventisit
Paul,
Thanks for the reply! The more information I can get, the better the results usually are. The seat has been a challenge from day one. The Ventisit seems nice, but I'm not sure how to approach the problems I'm having. One problem is that the back of my legs rubs the front edge of the seat base. It's mostly downward pressure and not rubbing side to side, and I'm experimenting with the cushion thickness , shape and composition to try and remedy that problem. Right now I have a 1 inch piece of closed cell packing material on the plywood base and there is a 3/4" thick piece of foam rubber on top of that then there is the seat cover which is breathable mesh. The overall angle is almost flat , but with a very slight nose high position overall.
I think tomorrow I will try and round down the front edge nearest the pedals and see if that helps at all. I do not have any medical issues with my legs or circulation, but on an hour's ride I have to stop and stand up for a few minutes to get the buns to stop aching. I do not normally ride fast or hard, so my effort level should not be a contributing factor as far as I know.
I do still love to go riding, but I hope I'm not doing permanent damage to my back side by not stopping more often to recooperate. Sometimes at night it feels like my back side is too tight- and those muscles are tensed up, but I think it's just lack of circulation.
Changing the bike seat angle was a big chore, but it did help delay the onset of the aching probably about 50%. right now the angle is at 56 degrees relative to the backbone of the frame which is almost parallel with the ground. I may have to go ahead and lower it some more, but you would not think that just 6 more degrees would make much difference in the comfort level? I could be wrong.
I'm shooting for a bike that you could ride all day without having to stop and rub out the ache. I don't know if that's possible, but that's my goal.
I'm 6ft tall and 155 pounds so nothing with a weight problem. however being 73 is probably not in my favor.
On your seat- does any part of the back of your leg touch the seat? It might be that my pedals are too low ( I built this delta trike from scratch without a computer assist- my main concern at the time was to have the chain not need any guide rollers to change the angle. - And for the years I've had this trike, that goal has been achieved. However, if I was to raise the bottom bracket even 10mm, it would probably cause the chain to rub on the underside of the front of the seat tubing- depending on what gear pair I was using at the time. So that would ruin my peace of mind really fast.
i think it is possible that the ergonomics are still a problem and I will need to end up with a guide roller like everyone else's design to keep the chain off the seat tubing while still having a full leg extension without hitting the back of my legs on the top of the seat tubing on the down stroke. Actually the leg femur is dropping too close to the seat frame in the front and the muscles there are having to deform to finish the rotation at the bottom of each stroke.
There are other factors with the mechanics of this trike frame too like the height of the derailer off the ground and the seat to chain clearance, so any changes I make now will have to be done very carefully if I am to not make things worse. Main concern is chain noise and I absolutely will not tolerate any of that.
