I can not use any electric welder due to a pacemaker, so I will use gas torch
As Popshot says, depending on where you live, it might be more or less practical.
It's a very old technology, and all the basic parts of it are pretty much the same - Whatever you knew before about it, still applies.
But, from your post, it sounds like you're unfamiliar with it - Gas welding (or brazing) uses an oxygen / acetylene mixture.
So you need 2 tanks, hoses, regulators, and a torch set - The torch has valves that control the gas flow, and the user controls the resulting flame.
You use a bare steel welding rod, making a molten weld puddle with the flame, and dipping the rod into the puddle, just like TIG.
For tubing, you only need smaller tips, maybe #0 - #2, depending on the make of the torch head.
You should look for an "aircraft size" torch set - I particularly like Smith brand equipment, and their AW1A torch is ideal for tubing use.
Good quality gas welding stuff is not cheap, and the torch I mentioned will cost more than some cheap electric welders.
Just like any welding technology, there is a huge area of subtle technique involved with gas welding - Way too much to cover here.
There is much to learn - It's not difficult, but it will take much practice to get good with it - Just like any welding.
But, with practice, you can get very good welds on steel tubing with it - They used it to weld airplane frames, after all.
I was thinking, your question about it sounds very familiar - Did you ask about this before, or on a different forum ?
If I had replied before, then my response probably sounds familiar, also
