A little bit of progress made ? so lets share it.
Having the car almost completely stripped I have discovered a couple of things not quite right with it ?
The one I have investigated and found a solution for was one of the half-shafts stuck when going around and took some effort to move past a certain point.
It was apparent it stuck in the same place and when giving it a good looking at I discovered this . can you see the bright crescent below the 54611 number.
The cause of this is the silver grub screw just above and to the left , I think the bearings only came with a single grub screw [ that is black ] and some one drilled and tapped for a second one , however the black grub screw is flush with the collar and the silver one is obvious much to long.
Easily fixed , and the other one will be treated the same.
I think I reported the seat is from a race car and in recumbent terms quite heavy [ 2.2 kg ], I tried and failed to get a couple of Windcheetah seats from the BHPC club , one was free however a 300 mile round trip and he could not post. The other the owner was some what taken aback when I mentioned I was going to cut off the neck/head rest part, now I had originally asked for a seat need some repairs not one good enough to use.
idly moving one of my polythene seats [ 0.97 kg ] around I dropped it onto the race car seat and they were quite similar ?
So I made a pattern on some wall paper and taped it to the back ..
I then proceeded to to cut the seat out to the pattern and drill some mounting holes in it.
I have not yet taken a picture of it , however it seems to have worked ! I now have a seat that is 1.32 kg almost 1 kg lighter a worth while saving. The seat is slightly more flexible than the polythene one it may need a little more work to make it usable in a race environment.
Now before you say ' use your polyethylene ' you numpty , I only have 3 , 2 of which are in use and I don't want to mount one in the car and then have to sell it with the car.
