No it can't.ps as can be seen
I am hoping my engineer friend has that in mind AFTER I have stopped him saying making new half shafts is the best solution.I can only describe an M8 bolt head as a failure waiting to happen for a drive system. The bolt head is effectively giving leverage over the bolt shaft because of the diameter differences. If they can't be milled on as Danny describes then cut a chamfer on the end of the shaft and fill it in with weld after putting a new bolt in. You are then removing the leverage and increasing the strength.
There's that too - Consider the bolts as sacrificial "shear pins", and replace often.if we make this part too strong
I think that was his plan and a few spares.An engineer could make bolts (themselves) from EN24 EN36C if at hand
Good luck, hope you get it going.
