Monday we finished my front-wheel mount on my quad and today we worked on the rear suspension and the diff.
The rear suspension isn't ready yet, but we did a lot more than I expected that we would do.
Here are some images.
The rear suspension arm. Not finished yet, be3there comes a triangle part on it. This will make that we can adjust the angle in 2 directions, so we can line out the wheels.
It also makes it stiffer and stronger.
203mm disk brakes, just as in the front. The disk brake mount isn't welded on it yet. We do that as we mount the wheels.
A fast test mount and everything fits very well.
One bearing on the end, because we changed the design. The other bearing comes on an other adjustable mount, so we get a triangle.
Using these parts, makes that we can change the design while building.
Testfitting the diff. The 20mm axles need to be longer, but we drilled the mounting holes.
The gears fit, even do I used smaller ones in my design, there is enough space for the bigger ones.
The 28t gear goes to the motor. That gets a 16t gear. That makes the gear ratio 1,75. This so we get more torque. We loose topspeed, but with a 2000w to 2500w motor on 48v, the speed will still be high enough. The quad is also not meant for racing. We need power for off-road. Still the quads will easily go over 25km/h.
I also decided how I want my camper part that comes on it.
It will be from foam with fiberglass. This makes it lightweight, strong and good isolated.
The main part will be 1,2mx1mx1m. In the front comes a plate tgat folds out with fabrick. This makes the total length to sleep in, 2m and the with by the wheels about 70cm, while the rest will be 80cm.the 70cm will be by my legs. Also this is ad least 10cm wider than I have in my current caravan.
The seat will be removable, so I can fold out the front.
Also will it get a roof over my seat and a windows that goes to the front bumper. This so I can ride also in the rain.
The complete camera part with roof, will be removable, so I can place an other luggage mount on the back. Also with a removable roof.
On the caravan build, I ad 3 camera's on in the rear on wifi tgat goes to my phone and 2 rearview camera's on the sides as mirrors with 2 5 inch screens that I mount to the roof.
Indicates in the rear and front. Brake lights and some big lights on the roof.
Heather and air ventilation in the caravan part.
Also 220v connections in and outside the caravan.
Hopefully we can finish the quads soon. Because I want to ride it.
