So peeps
Tried 2 different pedal cars as a short cut to owning a quad , both ultimately resulted in failure for various reasons.
So yet again I haul my wooden mock-up out of the bike shed and continue it's development:-
So far i have the seat , pedal and frame as low as I think it can go.
The front will be narrower than the rear to enable the largest turning circle possible.
Current dimensions are
W/B 44" and the front and rear track will be 28" [ bit wider than in the pictures].
Next to add is the chains one to the lay-shaft just in front of the seat and one down either side to the rear wheels.
The reason I am adding the chains is to see if there is enough room for a cassette and rear mech , without interfering with me , nor sticking the ground as effectively
it will be in the middle of the W/B , not the best place to have something dangling down !
I chose these dished IGH [ Shimano Nexus 7 IIRC ] to be drilled with 6 holes and bolt directly to the disc mount on the rear wheels.
18T matches the two Dicta freewheels I plan on putting on the outer ends of the lay-shaft.
This is slightly behind current progress however I have hit a snag , so will go on the general forum looking for answers ?
