Python touring tandem trike
So I started another project.
A python touring tandem trike, a spin off from my python suitcase bike.
The concept is: a covered storage box over the rear wheels which can hold 100+ liters of camping gear, the stoker on top/inside the storage box and with a python front end.
The trike is made of tree parts; rear storage box, in between boom and a python front, so it can be transported easily.
The python has 2 x 8 speed transmission, the stoker has a midmotor and a 6 x 6 speed transmission.
I want to ride the "way of the roses", a 170 miles (270 km) route across northern England, next year.
My original plan was to do it with the suitcase python unaccompanied,
but instead the plan is to ride the route both ways in 2 stages/weekends instead, I have 45 miles to the start and the route goes 15 miles north of where i live, so 1st weekend we ride to the start in Morecombe and ride the route back to our house, a 2 days ride, and then a second 4 days ride for the rest of the route and back home.
But first get it built.
Yikes that's going to be a load on the pivot ?
I have contemplated the reason why my python is twitchy and yours isn't, having very similar angels and setup.
The main difference is that I made the distance between the rod ends longer than you, if i remember right, yours was about 8cm and mine about 12cm, a difference of 1,5. So according to the formula on openbikes webpage http://en.openbike.org/wiki/Calculations my rod ends has 33% less radial force each, which, I presume, makes the front end easier to move and the python twitchy on higher speed.
So I'm going to keep the same distance, or slightly longer, than my python and the higher load on the rod ends, hopefully, makes it less twitchy.
The formula above, if I use 12cm between the rod ends, gives a 7.8kn load on each rod end, if the bike is fully loaded (200kg), the dynamic load rating for a 12mm rod end is 7kn, the static load rating is 17.5kn. I think a python pivot is in between static and dynamic, so it's doable.
I might keep a spare rod end with me when I'm touring.:)
Forgotten all about that , you may well be right.
Don't forget to beef up the mountings I broke some 3mm on mine built to the same design as yours !
failure
If using rod ends I'd think the quality of them may play a part in how easily they rotate under load too. The weight of the rider(s) will also heavily determine the load on them. Even if the stoker is 100% over the rear axle, the pilot is likely further from the rear axle meaning a greater % of their weight will be on the front. I agree with Danny in that angular bearings are the better option for this pivot or indeed any python pivot. Both bicycles and motorcycles use similar bearings but rod ends are simple shell type bearings. Cheap angular bearings will work well here but cheap rod ends will work differently to expensive ones under load with likely a high inertia or "sticktion" before slipping. It's possibly that sticktion that causes twitchyness. Paul's rod ends obviously work well but the window for working well would appear to be narrow. I would expect angular bearings to have a wider window with close to zero sticktion.
I will design the to the pivot as my first python, using a 80 x 40 x 3 rectangular tube cut into 2 U pieces, the different on my first design compared to yours is that I sandwiched each
rod end.
(picture from the archive)
This time I'm going square, using 40 x 40 x 1.5 for the main boom.
I think the opposite, having a longer distance between the rod ends makes my front end move easier and therefore be more likely to "twitch".
Mine is harder to learn to ride than Paul's but ones you are use to it is no problem, you only feel the twitchyness when you go past 20mph.
This python will be built for touring not racing.
I have already spent my cash on cheap rod ends so that's what I'm going to use.
The frame is slowly coming together. I started with the rear box and boom all from 40 x 40 x 1.5.
it's in two pieces
Inside the holes on the boom is welded m8 nuts so a bearing box can be bolted on top of the frame, which will also hold the frame parts together.
The rear frame is 900mm wide which is the total width, the wheels will be mounted inside the rear box.
The leftover box section was cut in halve and into bits, which will be part of the wheel frame.
The hibernation is over and it's full speed forward, well it was until today.
The pieces above has been assembled, and the outer frame pieces has been tacked in place.
This is the outer edge of the frame another will go parallel and the wheel will be attached in between.
I've got some novatec front and rear hubs and also a steel hub with tread on both side, to be cut in half, the bearing cup pressed out,
and used on each end of a 19mm axle with a six gear cassette on one side and a fixie sprocket on the other, so the total gear setup will be
6 x 6 gears.
When I designed the rear I wrongly thought that the disc brakes was on the outside and the difference was only 5mm from edge to center of wheel, but now I realised that the disc has to be on the same side and then the difference of the hubs are 20mm.
20mm difference between left and right edge and the wheels center line is to much.
One solution is to use the steel hub above on the rear drive side, hmm.
I could have gone el cheapo, from the beginning.
I think I have to sleep on it.
Sorry for yesterdays rant.
I have now slept and realised that yesterdays problem design choice was in error, so now it's full steam ahead again, until next design choice appears.
understood and forgiven ;)(y)
you really are out on your own with this , no one has built anything like it ?
Once it is built no one will know of the dead ends you travelled down to reach a ridable machine , it will just ' be ' in all it's glory.
Are you aiming for taking it to York Cycle Rally ?
Whilst I am going to the Netherlands and Pedal car racing in June/July I do hope to visit York Rally for the day [ probably all i will be allowed out :( ] I am already in a deficit for pass outs issued by the Higher Domestic Authority (n)
Every spring/summer I say to myself that this summer I will work allot on my projects, and every year I fail. My bike building normally comes after my chores, I think I have to change my work order.
So on with my project.
I'm using rusty old 1" x 1"16 square tube cut into 2 v shaped halves for my rear frame, the material, which been in a damp storage for a very long time, was painted on the outside before it went into storage and to my surprise the rust on the inside was very light.
I'm working on the front of the rear frame and have tacked together the rear seat area, so now I can work out where the rear pedals will be. I haven't decided if it will be a fixed or adjustable. When the rear pedals are in place I can make the pivot joint and then the front frame.
For the rear and front seat will use parts I never seen used before in the way I will use them.
I'm not to happy about my design choice for the rear frame, but I thought I leave it until the front is ready.
As always my progress is slow.
Since December I have made a adjustable bottom bracket holder.
So now I can build the front seat holder.
I've never been happy with the rear frames setup, the wheel are set to far in from the frame side, and there is little room for the brake caliper on the left side.
This is what i accumulated.
The rim is 16" and bought for the suitcase python, but 20" rims are available.
I bought 2 novatec front rear hub sets. 2 rear hubs and 1 front hub is needed in my design. I only need 6 gears on the rear, so I found a reasonable priced 6 gear cassette which I bought together with a 6 gear short derailleur to suit. When the cassette arrived it was a freewheel, I now know you cant buy a 6 speed cassette. So I bought a 7 speed cassette, hoping that the 6 speed derailleur will work on 7 gears. But its to narrow, the novatec hub is made for min 8 gears so a spacer is needed to fit the 7 speed cassette.
One solution is to buy the 20" alu rim and cut the flange and tread of the chromed hub, the 18 holes match nearly perfect with the discs holes, so by enlarging 6 holes to 6mm and tread the other holes to m4 and with a 2-3mm washer, to strengthen the hub flange with 12 m4 screws, sandwich the hub flange with the washer and the brake discs and have disc and the 6 gear freewheel on the same side, making the wheel closer to the side of the trike and moves the disc brake to the inside of the wheel. I will try this on the 16" rim before I get any 20" rims.
The now spare hubs, one rear and two front, can be used for my modular tadpole. the front hubs is made for 9mm drop outs but the axel is probable 12mm, I think they are using 28-12 bearings, cant take of the bearing cover, need a 19mm thin spanner, my larges thin spanner is 18mm.
If Sturmer-Archer can use 12mm bolts for there one sided hubs, so can I. If I cant find any suitable high strength, 12.9?, bolts I can always get Sturmer-Archer original one sided bolts, but they are expensive.
The bearing on the 16" rims, and probably also the 20", are 30-10, but by changing the bearings to 30-12 it also could be used one sided.
The rear frame is to wide so it will be rebuilt, my modular tandem design is done, and Im so pleased with the design that i might redesign this rear frame to fit in with the modules.
Kayfast on ebay are just down the road from me and have almost every fastener ever made in stock. They also use rm24 post as std. unlike many others.
