If your pedals are too close I saw this as a solution to a bit more inside leg room without moving the BB. The extender is free to rotate and this gives you it's c to c length in extra room. You loose a little crank length at anything before 90 degrees and gain the same over 90 degrees on the power stroke. The cycle is still perfectly circular. It's the first time I've seen these and thought it worth a flag up here.
