That's exactly what I need.You mean something like this?
Push and pull bars with a steering link across the two wheels giving Ackerman angles. If so then yes such a system can be employed on any tadpole trike including the Streetfox. As to how you need to set up the steering link first as per the std Streetfox then make the top arms on the uprights. Note how much the top arm moves from lock to lock and then work out how much bar movement you'd like to have to operate that movement range bearing in mind the bar lengths above and below it's pivot. IMO it's much nicer than dropping bars into the uprights and moving them left and right and feels fairly similar to under seat steering which the Warrior uses.
Is there a preferred angle to run the control arms (tabs) off of the spindle?Tank steering works fine. It's intuitive to use and just as good as under seat steering.
Only at the lever end , you need rod end bearings at both ends the wheel end swings around the kingpin moving that end towards and away from the frame. A small amount of out of line horizontal and/or vertical will work in may just limit the turning circle a little.It looks like the steering inputs are parallel with the tie rod? I think this type of steering will be easiest for my brother.
Or 12°I would argue the 80 degrees of caster is really 10 though.
Well Brad only said based on these drawings , you could also argue 80' is the head tube and 10' is the caster.I would argue the 80 degrees of caster is really 10 though.
