In a departure from our advertised program today saw the universe flipped by 90-degrees.
Well, OK just a Sturmey Archer 8-Speed flipped by 90 Degrees.
I found that if I turned the proposed dropout tabs to face the rear of the trike then the 8-Spd could sit inside the rear triangle.
It does create an issue in that the power-side of the chain will want to saw its way through the cross-rails of the seat (unless either the seat is raised, or a diverter pulley is employed).
No triple really required it is just conveniently on a bolt-up mount for testing purposes. BB could go below the frame but then any option for having a double/triple up front is taken away completely.thinking ?
do we really need a triple on the front ? looks as though with the 2 smaller rings there would be no seat interference ?
also could the BB go below the frame ?
Yes indeed. The available/affordable delrin blanks I got are only 60mm diameter so a little on the small side (76-100mm would be better).If making ones from scratch wouldn't it be better to design the sides in rather than bolt on something extra?
PopshotI got an already made pulley and merely turned that so it was flat on the bottom. It seemed easier than reinventing the wheel.
Hi Martin,Danny, is the bore a through hole or is it shouldered in the middle?
(Guess you have a middle spacer in there)
There are many ways to machine them.
With an end shoulder for one bearing, middle shoulder for 2 bearings.
You may need an undercut for a circlip to prevent the pulley walking off the bearings.
I've made 5 pulleys so far this year. Three different designs. Bought a 75mm dia black nylon bar 1 metre long, should keep me busy.
If making in 2's you can machine one gripping one end, turn round to machine other one. Then part off, with a long blade.
Use tailstock support.
Second load, bore operation for the other bearing.
Or if making singles cut the blank with a 10mm(ish) grip length.
Machine off excess.
Hope that helps.
I will making some with the centre sprocketed teeth next, such fun.
Martin.
Was this for drive side or return side ?
If drive side has it lasted ?
If so where did it come from ?
Hi Martin,
I am sure Nylon is fine but I had heard that over time is absorbs moisture and swells a bit, so I went with Delrin which doesn't.
And here is another one, it came out a bit better, may not need any side-plates.
I tried it with a length of chain for "fit" and it seems good.
Thanks, it is 60mm Dia by about 25mm overall width, with a 9mm channel in the middle and the bearings are standard 28x12x8 so it should be able to survive a bit of punishment.That looks like it could survive any worst case scenario yet is probably not overly heavy. Looks great.
