So LowRacer going on a diet [ like I should ! ] below is the rear end.
I cut the old axle off and one of the long seat stays after tack welding the other to the frame to keep the seat position whilst the bolts in the way of marking out the new joint were removed.
I have since made the cut freed the other seat stay and cut a 20" piece to go in , next up drill some 22mm holes for the new axle.
To lighten it further I need a new front end , either 20" wheel or as shown a 16" wheel.
This is the rear frame from a bike I found this morning with the rubbish in a local nature reserve after is was recovered from the river.
Most of it is pants however I wanted a BMX frame like this to play with so great news.
Next to the existing rear frame , so I need some steel to join the pivot to this part and then the pedals , the plan [ if it works ] is to use some
1.25" square made to fit under the seat tube welded to the rear mudguard bracket on the left hand chain stays and the rear brake bridge
on the right hand seat stays and all the rest cut off. [ then the stays will also be welded to this tubing.]
It will be propped up again with this tube parallel to the floor [ touch of OCD rearing it's ugly head ] and the pedals attached in the same place as these on the yellow part . Then it will be on to the pivot , the hard part.
Whist these are supposedly weight saving measures I am unsure currently whether to go IGH [ I have a Nexus 7 and a NuVinci 320 however neither are in 16" wheels [ yet ]] or as shown 8 speed cassette , which ever is chosen will need 155 cranks and 2 rings up front.
Lots to do Paul
