So there is to be a cooker/kitchen drawer on the left and general storage to the right of the bed base.[ see above ]
The front of the draw is to the left and we are looking into the stove part when standing outside the back of the car with the rear door up.
The pine piece at the front is to stop the cup/pans from falling out and the 2 tall sides will need to be covered in some thing to stop the heat scorching the wood ? need to find some cheap aluminium [ thick enough ] else I do have some steel sheet and a bender it will just be heavier.
All the above is held together with tacks whilst I plan it.
Now I want to use this stove [ yes a little odd ] however I have used if for over 10 years now and I don't see any point in buying another one that takes a different gas source. That is a recipe for having an empty bottle when you most need one.
Not seen anyone else use one so I am on my own with this , the low rail is to enable me to reach the on/off control and I though of leaving some space to put the cooking pot and cup down ? Not sure how far away from the wooden sides/front I need to be to stop burning the wood ?
So first up I need to fasten the base down , however it needs to be quick release as I only intend screwing the burner to the canister when I want to use the burner.
Looks like I can add a partition and keep some of my stuff in the right hand end of the drawer . probably couple of bottles with porridge/muesli in one and water in the other need some room for other food and my treacle !
Afterwards it needs a shelf that can fold out with a support on the front face of the draw.
