Good Luck! I hope it fixes it for you.
I found
this.
Trail Ranges and Characteristics
Very High
> 80mm trail
Extremely stable, solid feel at high speeds
Will lean heavily into turns
Best for off-road riding requiring self-correcting steering
Reacts quickly to light input at low speeds
High
65 - 80mm trail
Light feeling handling at low speeds
Stable, solid feel at high speeds
Will lean into turns
Responds more significantly to rider input than lower trail
Steering self-corrects more easily but may require more adjustments to hold a curve
Best with narrower tires (low pneumatic trail)
Shifting weight to steer has greater effect than on lower trail geometries
Mid
45 - 65mm trail
Moderately stable at low and high speeds
Will hold a line in turns
Low
30 - 45mm trail
Precise, quick steering at low-moderate speeds
Less affected by involuntary inputs such as cross winds
Stable at low speeds
Less stable at high speeds (vague, wandering feeling)
Requires more effort to lean into/out of a turn, but will easily hold a line
Best when balanced with extra weight in front and/or with wide tires
Trail balanced with wider tires (higher pneumatic trail)
Steering is less self-correcting than higher trail
Shifting weight to steer has lower effect than on higher trail geometries
Inconsistent Trail
As a bike design is scaled down to fit smaller riders, Toe Overlap (the tendency for the rider's toes to catch on the trailing edge of the front wheel when wide turns are taken) can become a problem. One approach bike designers take to mitigate this is to slacken (decrease) the Head Tube Angle in order to push the front wheel out farther from the rider's toes. This increases trail and, in extreme cases, can result in compromised handling.
One quick way to check for this design compromise is to see if there is a sharp jump in trail on the smaller sizes of a bike model.
