I got the wiring harness this morning - earlier than expected.
All the components were there, BUT! there's always a BUT!.
The diagram they sent with the harness isn't much good. It definitely isn't accurate and not much good as a guide either.
So I've taken matters into my own hands. What has been a benefit is the wires are marked as to what they are intended for.
Not that they will be used in that manner but it gives me a starting point.
Here I am trying to make sense of where each wire is attached, what color they are, and how they labeled them.
Have all the fuse sizes annotated and colored coded.
Next is to diagram out how the battery and converter hook up to this and then on to the switches/terminal blocks or components.
This isn't completed yet. Some terminals will be used for other components.
I still need to see how the fuse block is put together and how each connection works with other connections.
