Re-purposing a folding lawn chair.
A lot on the burner today.
But First
Started the day thinking the answer to making the windshield and post was this old basketball backboard/hoop.
And the resulting parts gained from taking it apart. Some useful metal parts for later ?
In particular, is the slotted 'seat adjuster'?, for another project.
Took a break from that and worked on cutting out a cardboard template, ( forth try)
for the cowl portion under, the soon to be fabricated windshield frame.
Mock set up with the 1" square backboard frame
Quickly found the 1" square frame looked to 'crude'. I abandoned this idea.
Note here that I still have 'move-in' tasks that need to be completed.
But I just wanted to do, 'something', on the build.
The old lawn chair had factory corners that were near perfect in size and quality of bend.
The lawn chair width was too narrow, so I cut out a 11" piece, to weld in, making the total width 31 "
Cardboard cowl in place and the newly welded windshield frame, in place to check for proportion.
Found the height, was to much. Needed to bring it down to just above eye level when in a seated driving position.
The final height will more than likely be between 48 to 50 inches from the ground. I will leave the extra, on for now.
No rush/need to cut of the excess, at this time.
The bar was lowered in this next photo. When seated, the driver (me), will be able to see the road,
just under where the fabric top will attach.
Also notice that the tool cabinet was moved to the other end of the shop.
It was only there temporary anyway, but quickly found out that it was in the way of using the band saw.
It is so nice to be able to move around, while working on this, without having to move something out of the way first.
