To continue on from the earlier discussion about making the parts in Stainless Steel......
A 1-Metre length of 304 (Work Hardening) Stainless arrived today so I cut a short slug off it to see how well/badly I could machine it.
It wasn't too bad. Facing up was easy with carbide tooling (clue).
What you see below is the slug of 304SS with a 12mm "rifle-bore" hole drilled through it and a 12mm piece of Silver steel inserted through the hole.
What did I learn?
My chuck key for the big-boys lathe is AWOL so I had to use the M2 taper chuck and key from the Chinesium lathe in the Boxford.
Even when starting with a centre drill to create a pilot starting point a 4mm HSS drill-bit doesn't like it. It just did not want to know, it was shrieking and un-twisting the flutes.
I swapped to a 5mm solid carbide bit and it went through the 304 stainless like it was just butter. So "Carbide FTW".
I then went back to quality HSS bits and stepped up in successive sizes 6, 8, 10, 12mm using lots of lube (she likes it like that) lots of smelly smoke but no snags and no problems.
Without too much hassle we have a snug 12mm hole.
Perhaps I should invest in a few solid carbide, carbide tipped or cobalt bits for the longer versions for the SA hubs.
What did I learn?
