bottom bracket for Timberwolf
Hello AZERs
I am now commencing the build of the adjustable bottom bracket (pages 139 to 147) in the manual. My choice for repurposing was an old Releigh but when I ground it down, I discovered big holes where the down tube and framing are welding into the bottom bracket tube. Really not a whole tube at all as shown in the manual.
Is there a certain type of bike frame I should be looking for that will yield a solid bottom bracket tube?
Dan
click to see image thanks
Doesn't matter that much. If it's a steel frame without collars and such, it's easely reusable.
Main problem over here is the lack of those old-timers. I run dead on Ali bikes.
Most bb shells will have those holes. Position them as best you can so the holes are covered by new tubes and weld in any left over.
Have you given any thought to mounting the bottom bracket under the beam instead of on top. I'm kind of considering this on my build if there is enough ground clearance.
The holes are there to let hot-air escape from the tubes that are being welded to the BB shell.
You can either have holes in the BB Shell or holes in the attached tubes to achieve this.
You can buy brand new BB shells with no holes from a frame supplies outlet. In the UK they are about £7.50 each.
Hi Steve:
I have not committed to the bracket being on top, and I can see some advantage to mounting it below. I am new to recombent biking and I have to say the initial "feet up" posture is a little off putting. I am trying for something more like you would see on an ELF where the feet are lower than your butt. So .....great suggestion.
Thanks Danny. Yes my neighbor suggested that as well, but I also need the cups and cranks etc for the drive train, so I am likely going to repair the holes of an existing Bottom bracket..
Hi Steve:
Probably going to put the bottom bracket on top as per the original design, and just make my seat higher.
as shown in HAPE 04's Fantom Project, the guy that inspired me to begin with
Hello AZERs
Dan
AZ offered bottom brackets for sale which had heavy walls and no holes since they were new. All used bottom brackets have holes to insert frame tubes.
All BB shells have holes in. It isn't to insert tubes though, it is to allow hot gasses from the welding to escape, else there is a loud "pop" and hot weld material sprays everywhere.
You can just puddle-weld them over if they are unsightly.
You can buy blank ones for about £7.50 each from frame suppliers.
Always insert cups in the threads when welding to ensure there is no distortions, and make sure you get the BB-Shell round the right way :D
All the donor bikes i used had holes as well, I used a piece of brass pipe and held it against the hole on the inside, and used it as a backing as i filled them in with weld then grinded them smooth. It kept the inside clean and I didn't have to worry about anything causing issues later in the build.
